Racing Radiator Swap
I plan to do this mod soon. i am going to go with the fluidyne radiator.
i have never installed one but it should be fairly easy. just drain the old one, unplug all hoses, pull it out, put new radiator in and fill.
the only reason i can see to do this is if you are running the car hard all of the time. this is going to keep your engine cooler vs using the stock one.
i am doing the install b/c of my blower. not that it is running hot or anything. it is just going to keep it alot cooler than normal. which = less heat soak from the blower which = more power.
panic
09-10-2015 05:56 PM
09-09-2015 10:30 AM
