People with aftermarket cams
I have just installed crower cams in my gt everything sounds normal
but the engine is shaking a little bit more than it used to. is this normal?
will this disappear with time? how many miles should I be babying my car?
and how do i know if everything is ok with my car?
RE: People with aftermarket cams
i think it would shake more with a rougher cam.. ive got another car that is cammed and it shakes more also because the cam isnt meant to idle very good (2200-5800 rpm cam). this could be what your cam is doing.
Sorry i didnĀ“t say what i got
crower cams 62800-2
http://www.crower.com/cat/domestic/f...amshafts.shtml
they suppose to be mild cams from Idle to 5500rpms
crower cams 62800-2
yeah the motor will shake more because its a hi-lift cam. rougher idle. Just like when your sitting at a light and you keep tapping the gas, the whole car would shake back and forth with the engine. thats all its doing in a way. your fine, i wouldnt worry about anything. if your that worried, take it to a performance shop and ask one of the guys there
ORIGINAL: StangGt01
I got my cams installed and the car tuned for right at a grand. This was with a new chip from the shop, the tune, and all costs to install the cams, and they bought the new cam gears (I bought everything else beforehand).
ORIGINAL: 2000GT4.6
You mean at idle? This is pretty normal. My stickshift even shakes quite a bit when it is at low idle. Also, I see no reason to baby it around. I left the parking lot of the performance shop with it to the floor.
i'll be tuning my car with diablo but for now i donĀ“t want to mess with that in this moment since i want to listen to all the noises coming from the motor
this friday i'll try it and let you know
ORIGINAL: StangGt01
i was affraid since i did the install myself and also i did a clutch install at the same time btw it's kind of low but i'll fix it
ORIGINAL: 2000GT4.6
The diablo has no feedback to tell it if your car is set right or not. Either get a A/f or get on the dyno!
ORIGINAL: code3GT
As small as those cams are, you probably won't notice much difference in sound.
hood i think that's just about what i need to achieve 300+rhwp i dynoed 287
before cams came will let you know how i'm doing
