Misfire? Transmission? Fuel Delivery?
Old 02-02-2009, 12:58 PM
lumberjack1
lumberjack1's Avatar
Default Misfire? Transmission? Fuel Delivery?
I've got an '01 GT Manual, about 86k miles. I've started to notice a pretty significant misfire, but only in 5th gear.
It feels like a lurch or stall, intermittent, and only happens when under throttle in 5th gear. Even at the same speeds in 4th gear, there's nothing. I need to change the spark plugs, likely, but I somehow doubt that's the only issue at hand--since if it was purely a plug misfire, I would imagine it would be happening in other gears as well. Does this sound like a transmission issue?
lumberjack1 is offline
Old 02-02-2009, 01:00 PM
Sxynerd
Sxynerd's Avatar
No,.,.
Sxynerd is offline
Old 02-02-2009, 02:38 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Sounds like a COP going bad. Misfires tend to occur during high load situations. Check for codes, and if you cant find anything, take it to a shop that can perform a cylinder "powerbalance" test, and see which cylinder is actually misfiring. Once you figure out the cylinder, replace the coil + plug and your problem is solved. Very common with Ford 4.6 + 5.4 applications..
WhiteFoxGT is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Omgitsa88Stang
10-05-2015 07:33 AM
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Misfire? Transmission? Fuel Delivery?
