Audio
Old 02-04-2009, 05:10 PM
Brute03
Brute03's Avatar
if you order from crutchfield, you'll get everything you need to make it work with the stock amps, however, i rewired the whole car when i put my deck in
Brute03 is offline
Old 02-04-2009, 05:14 PM
Sxynerd
Sxynerd's Avatar
Originally Posted by 64SoCalStang
If you have the Mach 460 Audio System, and still have the stock Headunit, you will have to rewire your speakers for the new Head unit. With the Mach 460 system, it uses amps to drive each speaker. This won't work with a new aftermarket headunit.
Dunn
Noobies that don't know anything should keep their ignorant advice to themselves.
Sxynerd is offline
Old 02-04-2009, 05:17 PM
Sxynerd
Sxynerd's Avatar
Originally Posted by tdcalhoun89
+1 the circuit city and bestbuy where I live wouldn't work on my mustang bc they "didn't have the right harness and couldn't get it" I believe there's two harnesses for the head unit though... it's tricky
I am a MECP Master Installer. Go to BB or Crutchfeild and tell/type your year and trim level and you can get the correct harness. It honestly takes longer to pull off the center bezel trim than it does to strip and crimp.
Sxynerd is offline
Old 02-04-2009, 07:57 PM
SoCalGT951
SoCalGT951's Avatar
+1 for sure
SoCalGT951 is offline
Old 02-04-2009, 09:43 PM
Jordan123
Jordan123's Avatar
I did mine a bought the correct harness and the speaker made a funny crackling noise at any volume. So i replace the speakers and it still did it. So i took it to a local car audio store and he had no clue and couldnt figure it out. so i rewired it all and problem fixed.
Jordan123 is offline
JoshyGT
09-19-2017 08:52 PM
JonnyBlazeGT
11-03-2015 01:10 AM
iamgobono
09-03-2015 12:37 PM
iamgobono
08-16-2015 10:50 PM
JJ94GT
03-18-2004 09:30 PM
Quick Reply: Audio
