I called Kenne Bell for the 2.1 twin screw for my 1996 and they said they don't make 96-98 blowers anymore due to issues they had with them. I don't think I want a centrifigal supercharger because that works off of RPM. Any suggestions on twin screw style blowers for my car?!?!?
That is an option, but I was looking into getting edelbrock cylinder heads and comp cams which are more aggresive than the PI ones off of 99-03 gt's. What do u think?
Do you mean the TFS heads? Because they are the only company to my knowledge that is releasing 2v heads. Either way I would swap to either PI or TFS heads.
+1, to my knowledge no one is making aftermarket heads for mod 2Vs except for Trickflow, and that would be a PI style head that would allow you to run a 99+ KB.
there ARE some aftermarket heads, and from previous threads on here, unless something has changed, the npi aftermarket heads are actually the best lol.
however, if you are going FI you dont always want the most agressive. ur pissing in the wind if you put a high overlap set of cams in there and try to boost it. you will force half your boost out the exhaust before the chamber closes.
