how much hp would the bbk 78 mm t/b bbk cai bbk l/t headers and bbk o/r x pipe flow master super 40s and a new intake manifold??
What mods do you have? Unless heavily modded the 78 MM TB will probally do more bad than good. Flows sound good but 90% of the guys here will tell you that flows and x pipes don't mix. The reason why is because flows are a chambered muffler. I was also going to buy flows and a o/r x pipe set up but when I went to You Tube and heard a couple gt sound clips of flows and a x-pipe it sounded real loud and as every one here will say raspy. LT's will be good. I got my shorties to cheap to pass over but I am satisfied, with the sound and performance. Hopefully this helps....
190??? no wayyy....please people whenever you post something make sure you are right, dont just post the first thing that comes to your mind, it doesnt help anyone here.
The only thing that's worth a midget's crap would be the exhaust, mainly due to the L/T's. The TB/Plenum will give you some throttle response and an aftermarket intake manifold won't net you much on a mostly stock motor.
