heads
can u use mark VIII va,ve cylinder heads are they the same as the cobra i wont to build them up so please let me know thanks
96 and newer Mark heads are the same other than the intake camshafts, older Mark heads had different springs.
if u put in on a gt it will be a lot of work from what i hear
bump
to the top |
please use the search function or look at the thread in my sig. This is similar to a very common question around here, as many of your other questions may be. So please do some searching before starting more threads. If you cannot find what you are looking for, many of us will be more than happy to help you out. Good luck, let me know if you cannot find what you are looking for...i'm sure I can help you, or direct you to someone who can.
