caliper closed up...help
Thats the point of the tool, to push the piston back in. Its the same as doin a rear brake job. You have to get it twisted and pushed and the same time. Doesnt matter if its 1/4" or 2", you still have to push it in the same way.. And those little cubes SUCK
why rent the caliper removal kit when u can get the cube thing for alot cheaper and u will never have to worry about not having the right tool again. whatever just me, everybody has their own style of getting stuff done.
i kinda agree, if the cube gets the job done, then thats what im gonna get. i cant really afford to waste an extra 20 bucks. i'm tight on cash right now...
because after you bust the sh*t out of your nuckels youll be wishing you got the other one....i thought "ill just buy the cube thing and save my money" that before i lost the skin on one hand and then threw the p.o.s. cube in the woods!!!
the cube has raised points different distances apart for the different calipers, then you put a socket and extension through the center hole and twist till the calipers is seated home
