Aftermarket Radiator Fan Install
Due to clearance issues i just purchased a Flexa-lite trimline fan. I was curious if you can wire this using the stock wirring? The Fan has a positive and a ground that is all, the connector for the stock fan has 3 wires. Is it possible to set it up with that stock wirring so it kicks on and off at temperature like the stock one did? or am I going to need a relay kit and a temperature probe and set it myself.
UPDATe: Ok i jsut checked the wiring diagram, the three wires goin to the stock fan motor are a ground, high speed, and low speed. According to the manual the only time the high speed kicks on is when the motor is hot AND the A/C is turned on. I have the A/C deleted on my car to begin with so By splicing the high and low speed wires to the power on the flex a lite fan and the ground to the ground the fan should kick off and on as normal correct??
11-10-2015 11:39 AM
