Dyno Predictions
Dyno Predictions
Im curious what i will put out on the dyno and im thinking maybe 260/270ish..... but im really more intrested in the torque. If i can hit 300rwtq ill be happy! The engine was just overhauled. I retained the stock bottom end while honing the block .20 over while keeping compression the same. Heads are stock with Houston Performance 292s cams, they are a mild cam i dont have specs on me but i believe they are a little more aggresive than the comp 262's. Modifications are
bassani xpipe
"Cat Back"
MSD coils
Cold Air Intake
BBK 78mm Throttle Intake
Circle D 3200 Torque Converter(20 lbs lighter, less rotating mass)
Nice Trans Cooler!
Nothing fancy but just wanted to get your predictions and remember this is through an auto
bassani xpipe
"Cat Back"
MSD coils
Cold Air Intake
Nice Trans Cooler!
needs headers if he wants to make any power out of those cams..... but my bolton stang made 260rwhp with stock head/cams/everything.
unless the stock manifolds are really hurting him i think u guys are pretty low.
Galactic
04-29-2019 02:56 PM
