Control arms rule!!
Control arms rule!!
So my buddy and I installed my GMS upper and lower control arms yesterday. I must say they kick azz! Much improved handling and traction. The car just wants to go straight instead of sliding everywhere.[:-] THe whole rear end feels alot more stable. I haven't got to go launch real hard on them yet.....[&o].....but last night I was messing around and lauched close to 3K and pretty much dumped the clutch and the bish hooked!
I was suppose to get my sub-frame connectors yesterday but the Fed Ex dude never came[]LOL. But those will be on next week some time....I'll let you know how they feel.
RE: Control arms rule!!
It went really well. We couldn't use the lift cause his dad had a bunch a shiz under it[:@] So on the ground was fun It took some time to get all the bolts out cause they were in some tight/akward spots. I had to re-use the bushings for the upper control arms were it attached to the diff. I wish I could of replaced those with some ply bushings[&o]....but they looked like a bish to get out anyway LOL
With the Steedas I got, there is no more rubber anything. It's all poly. I haven't really road tested them, besides a quick 5 minute run to make sure nothing fell off [:-]. My car goes on a 920 mile road trip on Monday, so I guess I will find out how good of a job I did .
I just installed my MM LCA's on Saturday. I got the adjustable ones and I can say there is a huge improvement. I agree that it hooks much better. There is like no wheel hop at all when you hit it from a dig. I can say this is a great mod to have done. The car does feel much more stable and handles much better as well. I ordered all the poly bushings as well.
Nanaki, I'm excited to get those subs on!! My friend and I will be welding them on. YOu have any tips on the install. I know that you are suppose to have the a-arms and rear axle on jack stands.
Snlpa, definately get some CA's with those 410's you got.
Those UCA bushings are a pain in the *** to get out. The easiest way to get them out is to drill holes in them and keep doing that until you can "wack" them out. The only problem I had with my lowers was getting that damn bolt out from the rear axle!
I called and spoke with a tech at Steeda and he said they have it down to a science. He claims that they can get those bushings out IN ONE PIECE and in about 5 minutes. I wanted to reach through the phone and strangle him. I used a drill and took them out in pieces. I then used a hole saw and a bur to get out all the crap that was fused to the inside of the housing. Major pain in the ***. The lowers weren't nearly as bad. I used an impact gun on that bolt and it finally gave.
