Other then IAC valve
What other things can cause a high idle other then the IAC valve. Its idleing about 1100 and its usually about 600. It seems to be different and different temps could it be the IAT sensor or MAF? I about to go plug the laptop in, but i have don't really know what to be looking for. Hopefully it will though a CEL. That was an odd thing to hope for.
I just check it. There was a P1507 code but it said See p1506. The MAF voltages looked right and so did the IAT. Maybe it is just a bad IAC valve. Anythought before i got spend money i don't have. (i have tried cleaning it.)
Yeah, that what it is. It weird i just got back form disconnecting it and checking for a change in rpm. One last thing before i replace it. For those of you that have clean it successully how/what did you clean it with?
I think they used carb cleaner, but it's a $50 part why not buy a new one?
Mine failed at 94k miles. Car would not run at all. I went right to Auto Zone, dropped 50 bucks and replaced it in 5 minutes. Car now has 99k and the IAC is the only thing I ever had to repalce.
It still runs as good as when I first bought it.
TfcCDR
09-14-2015 12:08 PM
