Bumpsteer kit or Alignment?
i have a 2003 gt which is lowered with c springs and tokico hp's just got some used tires and rims today and i notice that my car is pulling left and sometimes right. someone suggested that this is bumpsteer which seem to make sense. if i get an alignment (which i havent done since i installed my suspension) would this correct the bumpsteer since im not lowered that much? or do i have to buy a bumpsteer kit
http://www.latemodelrestoration.com/...0%201&comp=LRS
When you use the bumpsteer kit, it's best you replace the ball joints as well.
dude how used are the tires, worn out tires well do that, an alignment well help also how wide are the tires, wider tires like to follow the grooves in the road, i dont think the bumpsteer well help at all with your problem. get an alignment for sure if you havent since lowering the car, like i said it well help for sure.
the wheel gets pulled with undulations in the road. also for instance, if i go over a speed bump with only one side, the wheel turns to the side thats hitting the speed bump
it sounds like your car is reacting to the road and bumps very normally, you probably dont have bumpsteer, i had to same problems and set-up, added the steeda Bumpsteer and didnt notice a change
