1st Tune up any reccommendations....
Don't wanna tell you exactly what brand to go with.. but I will offer some priceless information that might seem like common sense to some.
MAKE sure your engine is BONE *** ICE COLD...no evidence of a slight bit of heat... TOTALLY cold...
and 2..
invest in a torque wrench and a long single piece extension to get as accurate of a measure as possible
and 2..
Hey thanks for the info.. I really don't think I'm making enough HP for an exspensive Spark plug. Gonna stay with the stock one's.
2010 Blue Ball Award Recipient
i had ngk tr55's...
but the head stripped, and i had to replace it *not the plugs fault* but i wanted to save myself from cutting off my ***** *again* so i went back to stockers w/o anti sieze,,, which i've heard is good, and bad
but,,,we'll see....
but,,,we'll see....
NGK are cheap and work great. I highly recommend using anti-seize on the plugs, but torque them properly (maybe even a little past specs). I wouldn't bother with wires, your wires should be fine. One of the things I recommend at that mileage is definitely using a cleaner or flush in the radiator. Also, grease up all of your bearing really well to avoid getting some of the common sqeaks and pops.
ALWAYS, ALWAYS, ALWAYS use anti-seize when installing new spark plugs. It is only $1 for a little pack of it, but it will save you $1500-$2000 if you mess up your threads for having a seized plug in your head, or worse, breaking a plug off in your head. Just use it!!!!!!!!!!!!!! It is the best dollar you will spend..... Trust me!
Hey thanks man! Gonna take you advice.....
jwog666
12-27-2021 08:09 PM
