Advantages to a dyno tune??
#22
Don't get caught up in this much timing is good. Then more must be better. If you paid your tuner and trust him then leave the tune alone. Changing AFR or timing without proper knowledge can be costly trust me I have seen it first hand.
#23
First off I not trying to be an a$$ I just want to ask you what sounds logical. If your tuner dyno tuned it and got the tune spot on (AFR/Timing). Using a calabrated instrument (dyno). Then why the hell would he tell YOU the paying customer. That you could add a degree of timing if you want. He should have never told you that. That is bad info to tell people to just start adding timing because you can. If he thought the added timing was worth the risk then he would have added it himself. Just my .02
#24
I had asked this same question about six months ago and someone gave me an article with the diablo tuner and advancing the timing if you run 93 octane u can advance your timing to the max 10* without harm. i will try to find the article and post it on here
#25
i have heard of that^^^ but me personally im not going to go do that to my car not knowing what its doing to my engine ya know? im not going to advance all the timing... ive heard that diablo is pretty much idiot proof and very safe and that its almost virtually impossible to blow an engine from the tuner itself, but im not going to switch things up unless i know what im doing
#26
Now remember all tunes are not the some examples auto x, drag racing, and 24 hr le mans would require a different kind of tune for each race. Lets take a look at the next example.
Lets say your car made 300 rwhp at 12.9 afr and 303 rwhp at 13.5 afr. Which afr ratio would you pick and why? Same goes for timing lets use 19* you made 300 rwhp, 20* 305 rwhp, 24* 306 rwhp 25* you get knock. What degree of timing set would you stop at and why?
This is the reason why you should use a dyno to do timing. You are able to justify the risk of the added degree of timing added. Most tuners would not even post info like this because it takes away from there buisness. I on the other had don't care because this is a learning forum and would like to help some people get a better understanding about tuning.
#27
I agree with everything that you've said. I Basically took the dyno sheet from the article with the stock afr that the tuner sets and with the advance on the timing that it showed. I took it up and test drove my car and it did feel like it was more responsive then the standard diable tune. I do agree that just maxing out the spark isnt everything but it seems to work well with the afr that is set with the tune. Now that i think about it if his afr was tuned with a dyno then the spark way need to be adjusted differently
#28
That is one reason why I still use the street/track to tune. Spark in my eyes should only be done on the dyno. You will be able to see the benifit of added spark like we said earlier.
I hope I answered your question if not post up again. That last sentence through me off a little.
#29
When u use the preset diablo tune im not too sure if it does anything to the cars original afr but i did not adjust mine further becuase i didnt have a dyno to know if what i was doing was optimizing it. But I had read an article saying that if you use the diable preset tune and advance the spark timing it had shown to produce about 12 more RWHP. With that in mind I was saying that my original post was wrong because I believe he said he did have his car dynoed to optimize afr. And he may not want or need to go as far with the spark becuase it may already be optimal. Pretty much just admitting that my first reply in this thread was inacurate.
#30
