help asap, knocking sound
#21
I have an 02 GT that is going close to the same thing.
The #4 plug blew out and I had that replaced, then I pulled the cover off and replaced the timing chains, sprockets,guides, and tensioners. After I put it back together there is a ticking noise that seems to be coming from the passenger valvetrain.
I unplugged each injector and the noise didn't go away.
When I had the passenger valve cover off I did notice some small shavings on the #4 rocker??
I may have gotten the passenger cam 1/2 or 1 tooth off when I put it back so looks like I'm going to replace the passenger cylinder head and hope the piston isn't damaged.
Good luck man. THis has been a PAIN IN THE A** for me
#22
well i dropped it off at the mustang shop last nite, they listend to it this morn but said it did not last long enough for them to find where it was coming from, so now they are waiting to try again with a steth, i will post what they find for everyone when i know
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
