Flushed differential..now gear whine?
Old 02-22-2009, 10:09 PM
vanquish
+1 I was thinking the exact same thing. The preload has a very specific torque rating.
vanquish is offline
Old 02-22-2009, 10:37 PM
bigmackloud
I agree with the above. definitely sounds like your problem.
RP does make an 85w140. kinda rare but we stock it at the shop I work at.
bigmackloud is offline
Old 02-23-2009, 08:57 AM
99BlackPonyGT
aka 'Negative Nancy'
but no 80w140, that ive seen atleast
99BlackPonyGT is offline
Old 02-24-2009, 05:10 PM
98GTstang
thanks for the help guys, im going to back off the pinion nut and see if that helps at all.
98GTstang is offline
Old 02-24-2009, 05:57 PM
stangalator
stangalator's Avatar
Haynes manual calls for "80w-90 GL-5 gear lubricant and adding 4 oz. of friction modifier when oil is changed"
stangalator is offline
Old 02-24-2009, 06:19 PM
vanquish
I think you need a new crush sleeve. Once you tighten it to set preload that crush sleeve is deformed according to the amount of torque placed on it. If you back the pinion nut off the crush sleeve is already crushed too far and may not fix your problem.
vanquish is offline
Old 02-24-2009, 06:22 PM
livefast1
livefast1's Avatar
DO NOT BACK OFF THE PINION NUT. like already said you've over crushed the crush sleeve and backin off the nut will cause major slop in the bearings and will almost definitly ruin your ring and pinion.
livefast1 is offline
Old 01-30-2019, 10:17 PM
lenko
lenko's Avatar
removed
lenko is offline
Old 01-31-2019, 05:24 AM
08'MustangDude
I noticed I got a little bit of a whine when drained and filled my stock Diff...
Wasn't there before, but it is now, and I used the right synthetic gear oil.
It's an open diff, so I don't need the friction modifier.
08'MustangDude is offline
Old 02-04-2019, 05:31 PM
WJL
WJL's Avatar
Post is from 10 years ago just saying
WJL is offline
Quick Reply: Flushed differential..now gear whine?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
