NX QUESTIONS
NX QUESTIONS
if i buy a plate kit, and run a 75 shot, can i just run colder plugs or am i going to have to back out my tune and run a stock tune again? or can i just change the parameters?
ohhh okay. When I said stock tune I mean performance wise (i.e. timing, fuel, global spark, etc) if you just want to make adjustments for like gear ratio and minor stuff then you are fine. Heck you could even bump up the rev limit a tad if you needed to, just don't go crazy on that since you still have the stock motor.
I would think so. Do you have a handheld tuner? If so you may have to have the guy that tuned your car make a N2O tune for you, which would basically be stock 'type' tune with stock parameters except for those few things if you didn't want to do it yourself. Make sure you still run premium fuel and a 1 step colder copper spark plug like a NGK TR-s (part # 4177) gapped at .035
you are correct BUT he already has a tune, which more than likely has some advanced timing in it.
