HELP NOT RUNING RIGHT
So is it still losing oil pressure? Sounds like you messed something up, or didnt replace the right bearing. Regardless, spun bearings wont cause stalling..
You're not going to find out much here because you need hands on help.. Nobody can e-diagnose an engine noise by a vague description
BUT THE IDLE PROBLEM WAS THE START OS THE PROBLEM NOT SURE WHAT IT COULD BE MIGHT JUST HAVE TO SEND IT TO A SHOP CUSE I HAVE NO CLUE
you do know below a certain rpm you can have oil pressure issues/ oil pressure drop. so in all reality there probably wasn't a bearing problem and your iac could be bad causing a very low idle to the point there isn't much oil pressure causing a knock.
I KNOW THAT WHEN MY RPM DROPS IT STARTS THE KNOCK CUSE THE OIL PRESSURE GOES NUT'S COULD IT BE THE IAC .
HOW COULD I FIND OUT IF IT IS THE IAC.
there should be a rubber hose from your intake going into the iac housing on your plenum. remove the hose and the iac valve clean it with some parts cleaner and put it back on. I have to clean mine out about every 30k. I should probbly just get a new one.
i'll try that in the morning when i get home and let you know thanks .
thanks to all for all the help so far
here are the results so far.
cleaned iac
replaced the mas.
now it's running right but at idle it is siting 1 line below 1 grand.
the oil pressure gauge is going nuts and it has a fant knocking to it sound like on the driver side head like a rocker..
any ideas please
cleaned iac
replaced the mas.
any ideas please
