H pipe install
03-03-2009, 01:38 AM
I had the same issue and used a mapp gas torch to heat them and they came off easily after a few heat and cool cycles. IF you use the heat try and get the flame on the bolt itself. Good luck,.
03-03-2009, 11:17 AM
i think i have a propane torch laying around somewhere, ill give it a shot and see if it works
03-04-2009, 12:17 PM
i broke off 3 of the 4 studs and just drilled them out and put in grade 8 bolts and nuts and it worked out great for me. as far as the pass side studs i got the hard one from the top side and the other from under the car... but im pretty wirey and got skinny arms so i could ha ha. o and i used lots of pb over the course of a couple days (had to let it soak). good luck
2007CalSpec
12-13-2020 11:42 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Webster454
09-07-2015 04:59 AM
Emblazoned
09-03-2015 10:45 PM
