JLT and strut tower?
I hope you mean strut tower brace? . I want pics if you decide to run w/o strut towers .
I, on the other hand, could conceivably do it as I run an SLA front suspension and strut towers are as empty as a good bottle of cab after a Saturday night dinner with the galpal. I think it will be crowded, but should pass underneath a STB. I run a JLT CAI, but do not have such a brace.
Jazzer
Jazzer
I have asked this before and if I remember there is only one manufacture that has one that will work with a 4" JLT ram air tube. Unfortunately It escapes me at the moment.
Now that is dedication, *thinking to self* this strut tower has to go if I want my CAI to fit...but how?" lol
Anyway, you may have to research that one a little bit, I have not looking into STB's myself to tell you which one to go with. If it is not the STB you are talking about and you are actually referring to the clearance b/t the tower and the engine, then i can help. It is a tight fit for sure, mine took some tweaking to get just right, I had plenty of room b/t the oil cap and tower, but my angle was off to begin with and just kept pushing and pulling and moving it until it found a nice medium. No rubbing issues now.
I have a Kenny brown STB and I know there is no way i could fit a JLT intake, i had to but the stock upper tube back on after I installed my plenum because the crappy ebay alumanium intake actually scrubbed on it.
Jazzer
Jazzer
+1 I have the exact same rear, but I really wish I had the Griggs double wishbone front.
and do your front summer tires scrub the fender liner at full lock?
also what about your torque arm, I scrape that everywhere do you have same issue?
lol sorry for threadjacking
^ Thanks
Nope, not as of yet
One day I will get one of those little devices that can be mounted onto the dash and give such a reading (cannot recall the name at the moment). I have heard they are quite accurate. I get a pretty fair amount of body roll, but boyyyyyyyyy it sticks but GOOD!
Jazzer
EDIT: I guess I type too slow, I will work on that. Ironically, my 295/30's on 10"s don't rub in the slightest, but the 275/35's on 9"s rub on fenders. That extra 1/4" or so is all it takes, I guess. I have my rack limited by one notch, but will investigate whether I can remove them. The torque arm does not rub, as the lowest point is just in front of rear tires. The exhaust couplers rub on EVERYTHING. I have about 2" tops clearance. The Oil pan is scratched up and the whole under side looks like pretty much hell . Fortunately, I have a steel reinforced Canton pan and all is good.
Nope, not as of yet
Jazzer
I have thought about heavier springs, but ride is already about all I want to put up with for a DD. Fortunately, I don't drive it daily
With all the spherical joints, it can get pretty noisy already. Run it over one of those really rough roads and my ride shakes like Shakira on steroids!
Jazzer
Jazzer
