Newb putting a '00 interior in daughters '96
Old 03-06-2009, 05:34 PM
klynam
klynam's Avatar
Thanks for the number Tommy - her name is Jenny (of course...lol)
klynam is offline
Old 03-07-2009, 12:06 AM
SVTeeshirt
SVTeeshirt's Avatar
haha im so glad you got that .
someone gave me that number once and i didn't even realize it untill i said it aloud
SVTeeshirt is offline
Old 03-07-2009, 03:22 PM
klynam
klynam's Avatar
I picked up the 2000-GT, 2-tone gray cloth seats today. They were in good condition but a little stained and very dirty from sitting in a totaled car and a garage.
Vaccum wasn't doing much and I was running out of upholstery cleaner. Then I thought heck, they're out of the car anyway, should I do it??? Sure...why not?!?!? So I went straight to the car wash and spent $4 blasting and scrubbing them with the big brush.
That certainly did the job - and they were definitely dirty. But I have to admit, I didn't think the foam would hold THAT much water...lol. Those suckers were heavy! Now I just have to get them dried out quickly so they don't mildew. They're outside on the back porch drip-drying with a big fan on them...
Got new tires on this morning. Kuhmo 235/50R17's mounted, balanced, installed for $460 out the door. I guess that's pretty good. It's done now at any rate.
While the wheels were off, I looked over the rotors. They all looked and felt good - pretty smooth w/ no gouging, just a hint of a lip at the outer edge, and they don't pulse at all. I was just going to put on fresh pads and bleed the system. Should I break down and put new rotors on now too???
Guess I'll look for a local buyer for the gray '96 leather seat set...
klynam is offline
Old 03-09-2009, 08:28 AM
2002GTforME
2002GTforME's Avatar
I would take them off and have them turned at a local machine shop since you are already there.
2002GTforME is offline
Old 03-09-2009, 09:35 AM
klynam
klynam's Avatar
Wow - getting the front rotors off was a HUGE hassle.
The two bolts holding on the brackets we're so tight I split a 15mm Craftsman socket getting them off!!!
Then rotors were practically fused to the hubs with rust and it took about 20 minutes of hammering and half a can of WD40 to break them loose. The driver side was so stuck I probably ruined the rotor surface hammering it off.
Unfortunately I didn't have a brazing torch to heat up and expand the rotors. That would have helped.
Taking the rotors to OReilys later today...
Do I need a special tool to spread the rear calipers? Someone told me they "screw" back in, not press in with a caliper spreader???
klynam is offline
Old 03-09-2009, 11:07 AM
2002GTforME
O'Reilly should have the tool kit you need, I think they call it "Ford Caliper Compression Tool Kit" or something similar, haha.
Old 03-09-2009, 11:37 AM
SVTeeshirt
SVTeeshirt's Avatar
atleast you get a free 15mm i've broken so many 3/4 drive ratchets because of rust, even with PB blaster or wd-40. Maybe once or twice because i should have been using 1/2 inch . Free replacement handtools for life FTMFW.
Old 03-09-2009, 06:18 PM
jwarner0297
jwarner0297's Avatar
with the tool for the rear brake calipers pulse the piston. If you understand that, it's like this: apply pressure then stop and release some pressure off the piston then apply it again.
Not sure you will have the same problem I did but that's what i had to do to get it to recess all the way
jwarner0297 is offline
mungodrums
10-07-2015 04:01 AM
Gkid182
09-22-2015 08:17 AM
MusicCity615
09-12-2015 07:05 AM
v8sn95
09-07-2015 10:17 AM
Quick Reply: Newb putting a '00 interior in daughters '96
