10% Overdrive crank, boost gains vs. pullying down
Would a 10% I/W overdriven crank give the same boost increase as going from 3.12 pulley down to 2.9RR pulley??
Obviously the O/D crank will keep more wrap on the pulley and you wont have to worry so much about belt slip but is the boost level gains still the same?
Redundant questions i know.
Also, what would be the benefit of changing the crank pullet over the blower pulley? Faster spool?
How do you know if you're getting belt slip if the Dyno graph doesn't fluctuate to show it?
I've never heard of someone getting Belt slip with a 3.12 pulley and I never had any possibility of complaints. I made way more power than I expected back when I had the 3.12 pulley. Is that normal for that pulley or just when dropping to the 2.9 pulley?
