I'm thinking he means stock A arms? My next question is why? Cuz you can use tubular A arms and then you stock spring perches and run the stock suspension set up.
I was thinking of swapping out the Kmember and later on after I've recovered a bit from the 7k that's been put into it already this winter, I'll buy the A arms and finish off the setup right.
What are the ultimate goals for your ride re: suspension?
I think you are going through extra trouble/expense piece-mealing this mod. I recommend you save your money up and do ALL the front-end work at one time. Decide if you want CO's and struts and make the complete upgrade at one time.
