HELP!! Idle problems
Hey everyone, I have been searching thread after thread looking for a soltuion to my idle problem but i am still at a loss as to what it may be. I have a 2003 5spd GT that has 95k on the odo, pypes catted X, Magnaflow mufflers, BBK 75mm TB, Volant CAI, and a Diablo Pred Tune. MY problem is at idle my rpms fluctuate from 900 to 400. this in turn makes the engine run a bit rough as you could imagine. when im driving the problem is gone and i see no jump in my driving rpms. I have replaced the spark plugs with OEM Ford Motorcraft, but i have the same problem. The only 2 things i could think of is maybe i have a coil going bad, or a possible IAC problem based on what i have read so far. I have ran multiple tanks of gas thinking that would be the problem but no change. any suggestions or help would be greatly appreciated.
Thanks
Josh
Thanks
Josh
Welcome to the forums and THANK YOU for at least trying to use the search function before posting a new thread, your one step ahead of the rest.
My Last mod was the Pred Tune, but that was done last summer, and i just recently started having trouble within the last month, so thats how I ruled out my mods (not saying they arent causing it, but just made sense to me). I'm going down to NAPA this morning and will purchase a new IAC, I hope this will fix the problem, i will also look into my hoses and replace if needed. Thanks for the replies everyone, I will post an update later this afternoon.
thanks
Josh
thanks
Josh
Im using the can tune from diablo. I went ahead and replaced my IAC and that did the trick. Thanks so much for everyones help. I really appreciate the quick replies. part ended up costing $56 with tax at advanced.
