low brake fluid makes the ABS light come on, not the e-brake. I would think your ABS light would be coming on from the ABS sensors detecting maybe some brake lock-up.
Wrong. Low fluid will set off the e-brake (!) light, not the ABS light. IF your brake light is coming on when you hit the brakes hard means your pads are low. Check your brake pads and replace the ones that are worn down.
