Frankenstien swap
Frankenstien swap
Alright so im really close to turning my GT into a cobra clone per say.
I have one issue that you guys may know. Some say with switching from a 2v to a 4v ill have a issue of 16valve vs 32 and things wont look good. Is it possible to directly bolt on a cobra 01-04 head onto a stock GT.
I will need,
new intake manifold
cam timing kit
likely new pistons, rings, gaskets, cams, rockers, ect. and a new computer couldnt hurt with a fuel system.
but is it possible or do i need to forge it out.
I will need,
new intake manifold
cam timing kit
The heads will bolt right on. Pretty simple swap. You can still use the stock computer and harness with a tune and some modification to the harness. The fuel pump and injectors will need to be upgraded.
You also need timing cover, exhaust manifolds, fuel rails, cams, oil pump.
well i plan on putting the eaton on until i can afford a KB.
I could buy a engine but then im just like eveeryone else. I want to be different and take pride in it. I assumed i would need some more parts and thats fine.. thanks for the help ill find that sticky
Matt's 95 Stang
10-05-2015 07:16 AM
