What suspension package should I go with?
My 98 Cobra is currently under major mods with HP in the 1000+ range at the wheels. For this much power, I expect to have major traction problems. I currently have Nitto 555s on the front(265/35) and rear(285/35) and will be changing out the rears to 305 drag radials. The car is still in the shop but it is getting close to decision time for the suspension. I havent' decided on what suspension package to use other than the front will have coil overs that go with the new K-member and control arms as part of the Twin Turbo package. I have been looking at Eibach's Pro Street coilovers. Does anyone know what package will do the best job of overcoming extremely high horsepower?
well... no cutting corners with this one...
talk to teamz suspension
hell you may want to look into panhard bars, and a tq arm...
you can stay with a stock style spring in the back, most all of the renegade guys do
and a drag radial? itll never happen...run 15 inch rims, and atleast an et street style tire... the sidewall is going to help your cause
I would CALLboth Maximum Motorsports and Griggs Racing and talk to them, describe what you want out of your car and compare prices.
A lot of time if you are talking to both companies at the same time they are willing to talk each other down and you can get a good deal.
I agree with others an NO time to cut any corners.
I would certainly go PHB/Watts-Link with torque-arm and recommend MM or Griggs for sure. I also think you need to put good rubber all the way around as you need to stop and turn all that power once in a while
Jazzer
Jazzer
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
