brake pedal going all the way down - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 03-21-2009, 03:36 PM
tony02gt
Default brake pedal going all the way down
hey i have an 02gt just changed the pads on the front got in to drive it and the pedal goes all the way down to the floor before it stops. drove it around the block and it still does it. am i going to have to bleed the brakes and if i have to do i just need to bleed the front brakes?
tony02gt is offline
Old 03-21-2009, 04:28 PM
96GT34
sounds like u got a busted brake line, if all u did was change pads then no u shouldn't have to bleed anything
park it on concrete or blacktop and pump the pedal a few times, look underneath and see if u see a puddle
if not look around the bleeder screws maybe ones came loose somehow
96GT34 is offline
Novanutcase
Novanutcase's Avatar
Sounds like you need to bleed the brakes. Do the fronts and drive it around. If it works then you're done.
John
Novanutcase is offline
Old 03-21-2009, 10:27 PM
Vovovovan
Vovovovan's Avatar
it may be a caliper, i had that problem on my sixer, had to change the caliper
Vovovovan is offline
Old 03-22-2009, 12:41 AM
zkeele
You also could have air in the master cylinder. Bleed it after you bleed the lines.
zkeele is offline
Old 03-22-2009, 05:59 AM
MineralGrey
MineralGrey's Avatar
bleed the lines and did you pump the brake pedal until it got stiff before you took it out?
MineralGrey is offline
Old 03-22-2009, 07:30 AM
Pohatu18
+1 I changed my front pads backed it outa the garage and my brakes didnt work I slammed it back into park before I got going to fast and pumped the brakes.
Pohatu18 is offline
Thunderball
15
11-23-2015 12:49 AM
Matt's 95 Stang
10-05-2015 08:16 AM
guitarman376
09-30-2015 06:54 PM
09-25-2015 07:42 PM
ThatJuanStang
09-25-2015 09:01 AM
Quick Reply: brake pedal going all the way down
Featured Sponsors
