HID Install Need Help!!!
I just purchased an hid kit from vvme.com for my stang and on all the other post in here with pics on where things go they show two blue sockets that i guess go to the original wiring harnesses. Well my kit has only one coming from my controller so im not sure on where it goes. I have everything hooked up together out of the box except for the grounds, one positive wire that goes to the battery and then the one blue socket. In the pic with this you can see the blue socket at the far bottom left and the positive wire with the fuse that goes to the battery to the right of it. Like i said the only other things that arent plugged in that picture are the grounds i believe. Any insight would be helpful especially from those that have used this exact kit from vvme.com Thanks
blue plug gets plugged into the driver side, there may be an issue with the way vvme has them wired, I believe half of the units they sell in america have the highbeam and lowbeam wire in the wrong position. Swap them if you have issues and you'll be fine.
09-10-2015 08:39 PM
