I start my car every morning for work and go back inside and watch tv until the car is completely warmed up. I will not drive the car unless it is at operating temp.
The temp. gauge is the coolant temp, right? How long does motor oil need to get warm for high rpm piston-to-cylinderwall sexy time?
212* is what engines are designed for, with a viscosity of 10. At 300* (Track conditions) the viscosity is at 3. The key is to balance the flow vs. viscosity. (flow does not equal pressure).
0w30 lubricates just as well as 5w or 10w30 and would be my choice if I could find the Mobil1 as cheaply.
Here's a excerpt from a great article on-line. 30 weight oil:
thanks for all the help. one more question, my car for some reason has a hard time going into reverse, if i let off the clutch then engage the clutch again it works sometimes, or if i go 5th then to reverse, but sometimes it takes 1 to 3 trys to get it into reverse, do u think i have tranny problems of this normal, when it messes up you hear a gridning sound like i pushed it into some that was moving, 111k on trans, i heard thats normal thu having troubel going into reverse
