what plugs to use?
RE: what plugs to use?
If you don't mind changing plugs every year a nice set of Motorcraft Coppers are good. NGK Iriduims are nice. I just installed Denso Iridiums, pricy though, but had good luck with them in other cars and so have my friends.
ORIGINAL: code3GT
NGK TR55
NGK TR55
NGK Iridium TR55IX Spark Plugs
http://www.lmperformance.com/4800/50.html
Iridium is a precious metal that is 6 times harder and 8 times stronger than platinum, it has a 1,200(=F) higher melting point than platinum and conducts electricity better. This makes it possible to create the finest wire center electrode ever. Prior till now, platinum had been favored for long life or performance spark plugs due to its high melting point, also the technology did not exist to machine and bond iridium on a spark plug electrode(at least in a cost effective manner). Iridium industrial spark plugs have been around for years, but still sells for over a hundred dollars per plug. Just now is the technology available to effectively use iridium in a spark plug for automotive applications. The strength, hardness and high melting point of iridium allows NGK to manufacture there iridium ultra-fine wire center electrode to 0.7mm. One of the finest firing points in the industry! (Thus far there has been no problems reported regarding use of iridium plugs with nitrous oxide.)
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
