How are the WOT switches in those kits compared to the Zex TPS switch? Did you hook yours up to your gas pedal or your throttle body lever?
But I see dynotune has a TPS switch too that they sell
In the HSW kit, it is just a small microswitch. I mounted mine so the tb lever triggers it. They are cheap and easily replaceable, the Zex switch on the other hand isn't.
The zex kit is very easy to install. The zex kit has a pretty trick fitting that bolts on the fuel rail. The Zex kit doesn't rate there hp to the wheels though. Doesn't hit that hard.
Rating at the wheels or not isnt that big of a deal. You can always just go up one more step and the results would be pretty close.
+1 i got the switch from radioshack tho for my NXwet kit. loved it.. but my buddy who has 2 1/2 ton axles with 52'' tractor tires on his yota wanted it. so i sold him the kit lol
