won't start after accident what should i do?
i have a 98 gt that was in an accident its back together but won't start its not getting fuel. i checked the relay thats good. i checked the button in the trunk thats pressed down. when i turn the key the thieft light flashes rapidlly. if anyone has had the same problem or knows what to do i sure could use some advice.
does the engine even crank? a pats fault will disable cranking.
are you using the correct key? the pats transponder around the lock cylinder could be damaged. fuel pump wont make the theft light flash, dont waste your time.
no it was hit in the front end i have all that replaced the button in the trunk is down. its cranking but there is no fuel getting to the engine when i turn the ignition on the theft light still blinks rapidly. all the conectors are good for the wires i went over them a few times. the fuel pump relay in the fuse box is good i tested that.
