Stage 2 Cams on stock block? Too much?
Raise the rev limiter up to 7000rpms but only rev to 6500. You don't want to bounce of the rev limiter that one of the worst things for your car. My rev limiter is set at 10,000rpms cause the tuner hit it once by accident when it was set just above 7000. I rev up over 7000rpms all the time
if your tuner knows what hes doing then he should be able to adjust accordingly like stated above. you need to shift when the cars hp curve starts to fall, just raise the rev limiter above that to keep from overspinning
what does the stock rev limiter kick it at? 5700rpms?
So Im going to ask him about increasing the limiter, but what problems can this cause (down the road?) What can I do in the near future for the car to safley handle 6500 rpms?
09-08-2015 05:21 PM
