ByPass Question
ByPass Question
Friday night I opened her up from 80mph to 150mph up a hill for about 1 mile. I went to start her up on saterday morroning and she was reving at 200rpm and there was smoke coming from the exhaust. I shut her off. I opened the hood and I could not believe what I sow. I blow the bypass valve right off. The bolts that hold the bypass on were guin. I had it fixed saterday but I wanted to know could there be motor damaged and has this happened to anybody before. She sound and runs fine now. The guy that works on my car said he has never hear of anybody blowing the bypass valve off and I have never hear of it too. That's what I get for driving at full boast up a hill for 1 mile
I did not take a picture of it but this is the bypass valve. There is 2 bolts that holed it on. In the picture you can see the top one.
[IMG]local://upfiles/15077/CCC01B4A02354843A4963399F0E6F50C.jpg[/IMG]
RE: ByPass Question
Sorry maybe it is the IAC valve. Why would it blow off like it did. I've had the s/c for 3 years and that was the first time I kept it at full boast for 1 mile in 4 and 5 gear?
Thanks
[IMG]local://upfiles/15077/88AC559F9B2F47F891E4FAE3159269BF.jpg[/IMG]
Thanks
RE: ByPass Question
That is the IAC and the plug on top of it is referred to as the IAC bypass sensor. If you blew it off then it should have immediatly messed with the idle. But if its running fine after the replacement is installed then I would say you probably didnt sustain any significant damage.
RE: ByPass Question
The hole silver part came right off. It was lieing on the fuel rail. All I had to do is get two new boilts to put it back on. I did not replace any parts.
Dose anyone now way this would happen.
Thanks
[IMG]local://upfiles/15077/62B01BCEB2D349D7B979191B0CC596E2.jpg[/IMG]
Thanks
RE: ByPass Question
ORIGINAL: BicketyBam
I kant help u. I reely hav no klew. Sory.
By the wha do you go to the show on friday? I did not go, I went out with my girl instend. Sorry if you went.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
