the one closest to the shifter is not working. Could someone post a picture or a diagram showing how many wires or something comes out the back of it. i had 3 coming out because a speed-cal was attached and now it doesnt work. i will also check the fuse for it too.
Cig Lighter there should only be 2 wires, 12volt and ground....Fuse is in the fuse block inside the car on the driver side.... I believe its a 20 amp fuse.
