Check Engine Light/ PCM
So I think I fried my computer now. All of the dash lights work but the check engine light does not light up when the key is inserted and turned to the on postion. Also I hook up a code scanner to it and it will not allow me to read codes or check anything. Anyway I can tell if I toasted the computer.
Check the fuses I bet the fuse for the DLC is blown
data link connector has power but it will not read anything on the computer
I forgot alos check the fuses to the pcm also, check your grounds too
pulled the carpet back out and had damaged a wire by the computer. It ended up being the fuel pump. fixed the wire, car runs great. time to put the interior back togather
Originally Posted by 4.698GT
(Post 6120864)
See, now you were all worried about tossing a fuel pump in there and whatnot. Didnt I tell you to check the circuits for power first. You'da been mad as hell if you threw a fuel pump in there and still had the same problems. Atleast you got it figured out now. |
