how much do you think the set up you stated above would run?
well to get the most out of the combo id have custom cams grinded which may or may not be more, the heads are at least 2000 for a good set, you could probaly forge the motor for 1500 if you do your own work, and 1500 for a good nitrous kit with fuel pump and injectors, another 1000 for a good int. manifold so probaly 6500-7000 if done right but that may be on the cheap side. but the tranny will have to be strengthened, and the same for the rear. and its not safe to run stock suspension with that much power so that will have to be upgraded. its not as easy as slapping twin turbos on and making 900hp. it takes a lot of time and $$$$.
