AFR Question
Old 04-21-2009, 08:27 PM
Nolimits31
Nolimits31's Avatar
Default AFR Question
Today when i started the car up i let her idle for awhile and i noticed the a/f was between 11.6-12.2. she usually reads around 13.0-14.2 but why such a difference today? is this safe or should i contact my tuner?
Nolimits31 is offline
Old 04-21-2009, 08:28 PM
mustangman281
Banned
mustangman281's Avatar
What is the temp outside?
mustangman281 is offline
Old 04-21-2009, 08:31 PM
Nolimits31
Nolimits31's Avatar
today it was about 55 with very little sun.
Old 04-21-2009, 08:34 PM
mustangman281
Banned
Did it stumble at all or run rough?
Old 04-21-2009, 08:39 PM
Nolimits31
Nolimits31's Avatar
no everything sounds normal at idle i didnt take her out since it was on our lift at the shop cause i am trying to figure out an emissions problem. maybe you can help me with that too, i get a code p0443 stating emissions system purge valve circuit and i replaced the silonoid in the rear of the car that connects to the vaccumm canaster and that did not fix the problem. what else should i check.
Old 04-21-2009, 09:16 PM
mustangman03
mustangman03's Avatar
could be a wiring problem
mustangman03 is offline
Old 04-21-2009, 09:20 PM
vanquish
vanquish's Avatar
What wideband are you using? I'm using an AEM and sometimes I have to drive my car for a while then the AFR's get more consistent.
vanquish is offline
Old 04-21-2009, 09:55 PM
01GT4.6
01GT4.6's Avatar
I think (could be wrong) that I had that same code when I had a vacuum line to the gas tank loose, but I think the gas cap with throw the same code as I had...
01GT4.6 is offline
Old 04-21-2009, 10:17 PM
jvog
jvog's Avatar
When I start my car up it hovers around 12 everytime. Once it warms up it reads around 14.5
jvog is offline
Old 04-21-2009, 10:20 PM
Nolimits31
Nolimits31's Avatar
yea i think it will be just fine now i need get this gd service engine soon problem taking care of it is driving me crazy. o by the way it did not come on until after i had it dyno tuned. maybe something my tuner did?
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: AFR Question
