HELP, broken somthing....
Ok heres the thing, i went tonight to set a new best time, before i started changing things. New best time of 13.39@102.33 from previous best of 13.79@102 needless to say im happy...had more room to improve to, now the problem...I think i friend the posi after that run, so only driver side tire does a burn out. Question is, will it get worse? can i just drive careful for the next 2 months? or will it be dead in a week. Plus i am only assuming its the posi because i didnt feel anthing snap, so i dont think its the axle but im not sure. any help or advice or maybe someway i can check it without spending money would be much apreciated. Thanks
You'll be more than fine to drive on it. You just need to get a T-lock rebuild kit to replace those little clutch disks.
If you were planning on gears then now would be the perfect time. Nice new time BTW, thats pretty impressive.
If it was your axle you wouldnt of been able to make it home unless you had a trailer
sweet i was hoping it wasnt bad, but im still pissed because i still think i have a 13.2 in it but alas 1 tire fire brought be back to 13.6ish13.7 and horible 60 foot times.....still managed to stop a new mustang doing that tho...lol on my record run i was against a 98 z-28 NA with exhaust and intake i think, running full slicks, and i rode his *** the whole way down the track, he pull a 1.8 60 foot tho and ran 13.1xx
and of course now when i fix or change somthing the car is gonna be completely diff...so my time wont be as impressive, unless someone thinks just gears and DRs on my car with a 12.xx time would be impressive...heheh
oh on this subject...if im to lazy to do it myself, ive never torn a rear end down....how much do you think it would be to have someone rebuild just the posi? or is it just as expensive as gears?
not to be a stickler, but #1 Positraction (posi) is Chevy, shame on you
It's probably just the spring in the dff causing your heartache,
I haven't had to replace one, but it looks pretty simple to fix.
Also, you shouldn't worry about what other people think is impressive. If you have that car to impress people, it's a losing battle. I personally just race for fun. No matter how fast you go, you will find somebody else faster. No big deal.
Good luck man!
Good luck man!
true that, i do have fun wouldnt risk damageing my DD for other people thats for sure. still have no idea how to do a rear end, need to replace the whole thing with a 31 spline unit anyway
09-25-2015 06:58 PM
Calizic
08-28-2015 01:46 PM
