03GTwhos |
04-26-2009 05:37 PM |
Need Help!!!
I recently installed LT's on my car and removed the K-member to do it. I unbolted the Steering rack-and-pinion and tied it to the Swaybar. When I put it all back together I could hardly steer it out of the garage. Everytime I would start the car it would drain the resevoir, but there was no puddles and no leaks at all. Everyone was saying it's low put more in and it has air in it put some more fluid in it. Where did it go cause it was full before I installed the LT's. So now I have filled it back to normal level and you can barely a squeal or feel it in the steering wheel when turning. But it is leaking from inside the drivers side boot and the passenger side looks wet to. Here is a pic for those that want to see. Any help or info would be greatly appreciated.
Thanks Matt
