Electronic seat adjuster.
Quick question, im stuck at work, so I won't get a chance to check till later. Does the drivers seat electronic adjuster have its own fuse? Mine stopped working last night. the adjuster panel itself is very loose, but it hasn't had an issue before, so im curious if thats a possibility. Otherwise Ima pull the panel off and check the wiring.
It's not electronic, it's electric, and it does have a separate fuse--it's a 30A fuse, fuse #18 in the battery junction box (under the hood)...
ah, tyvm, sorry for using the wrong word =P. I'll give it a check when I get off work thanks :)
Originally Posted by Matthew_B
(Post 6152783)
There's a big difference between electronic and electric--mostly in how complicated it is to diagnose, and how much it costs to fix... |
