What do i hook the vacuum line up to from the bypass?
I recommending buying a tee, unplugging the main vacuum line from the throttle body, and putting the T in there. Then run the middle part of the T to your valve. Kind of hard to explain, I wish I had a pic
There is a nice place to put the tee in on the right side of the car around the firewall. There is a white nylon straight connector there stock connecting two vacuum lines. Just take it off and replace it with a tee. I can get a picture if you want.
http://www.fquick.com/garages/viewga...wimg&id=224650
if u follow the line i tied into the little red hoses..i havent had any problem yet.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
