What is the easiest way to pull the motor?
Well, I am not going to risk my motor on it knocking, so I am going to pull it out. What exactly is the best way to do it? Out the top, or bottom? I have the means to do either, but it sure doesn't look like that motor can come out the top. What is your take? It's a 96 GT BTW.
Good luck. i went back to 5.0's after dealing with that car lol
If you have a lift the easiest way is to put the k member on jack stands, un-bolt it, disconnect everything, and then lift the car right off of it. That way there's no hassle fighting with the hoist and swinging it in/out.
It's not hard out the top, but it's much easier out the bottom.
Thanks guys. I will take it out the top. I don't have a lift, but I have a giant H frame with a hoist on it that I can pick the body up with. I did it with my 98 Cadillac when I had to pull the motor. Not exactly fun, I would rather take it out the top.
Yeah, out the top was easy enough. 6 hours to get the motor out. Would have been 5 if I had figured out that the inspection plate was what was holding the transmission to the engine. Does need two things that are going to be 1000% easier to fix now that the motor is out. Throwout bearing and the motor mounts are shot.
jaiidutch
09-14-2015 10:29 AM
