Focus fuel pump install help..
Ok this morning i am going to install my svt focus fuel pump, does anybody know of a site where i can see a good write of of this install i know it's notjust drop in and you're good, you have to retain a factory part of the fuel fpump...anybody have any info?? pics would help thanks
-Mike
-Mike
RE: Focus fuel pump install help..
ok well i pretty much found my answer on how to do this...not hard at all... if anybody else is interested, http://www.dndgarage.net/focuspumpinstall.htm its all there..[8D]
-Mike
-Mike
That's the gist of it. It's not a piece of cake but once it's done, you'll be glad you did.
There are just a lot of annoying connections including fuel and electrical(the worst is the tube that comes from the gas cap cause it's in there pretty deep).
Make sure to have a flashlight (or two). I recommend doing it when your tank is practically empty to minimize spillage (especially since gas is so expensive). Your gonna spill some gas when you disconnect the fuel line. when I did it, a buddy of mine had some plastic things that made disconnecting the fuel line easier. You may want to talk to a local shop to see if there are any cheap tools to help.
kawiguy827
09-01-2015 07:09 PM
