SO I figured out the chirping - now help me fix it!
This is my third thread about this problem so if you remember what's been going on then sorry for the recap. For those that don't know what the problem was, I have been getting a weird "chirping" noise in my engine bay for a couple months now. It responds to throttle only and doesn't matter what the clutch is doing. It's gotten worse and worse (louder and faster) over the last couple weeks especially. I had a mustang performance shop try to figure it out while I was getting some other work done and they couldn't. I've taken the belt off to run the motor and it still made the noise. There is a video about half way down this link that sounds exactly like the noise I'm getting.
http://allfordmustangs.com/forums/4-...-gone-bad.html
SO.. today I took apart the upper part of the intake system, changed/cleaned gaskets and put clamps on all the lines. I also swapped the places of two COPs. After starting it up, it was still making the noise but much slower and louder (like releasing a lot more pressure just less often) I messed with the COP that it seemed to be coming from. If I wiggled the plug as much as it would let me, the noise stopped. I've actually been able to get the noise to ALMOST go away completely after messing with it. It's still there, just very faint.
So what do I need to do? If there is air coming out of the spark plug hole, what does that mean exactly? Do I need to replace the plug to be safe? Should I replace all if I replace one?
It means you have a loose spark plug--do not drive the car another inch until you pull that plug. Hopefully you will have some threads left in the head an be able to reinstall the plug and properly torque it (11 to 13 lb/ft).
I think I have the same chirp noise
I have only had my 99 gt for about three weeks and I have been hearing a strange chirping noise from my car too. I was thinking it was the serp belt off the kenne bell or a pulley but but it sound slike a little bird mostly when letting off gas at slow speeds or maybe I just cant hear with the supercharger whine or magnaflow kickin. How hard is it to remove coil packs to check. I peeked under the hood and it looks fuel rails need to come off. I hope not. Any info about plug removal would be great
I have a lot of junk built up in the socket and no air compressor. How should I clean it out before I remove the plug? I dont want any of that crap to fall in my head. I have 0 power loss so I doubt anything has gone really wrong yet. I guess I'll go to the store and pick up a new plug and some anti-seize
