3rd gear grinds on fast shifting
Old 05-27-2009, 01:58 PM
cisurfer
cisurfer's Avatar
Default 3rd gear grinds on fast shifting
Recently my 3rd gear has been grinding every time i shift faster than normal. I cant race without it grinding or even shift fast, im not even power shifting. Is it my synchro or could it be fluid related. I changed from royal purple to penzoil and thats when it all started. Should i switch back?
cisurfer is offline
Old 05-27-2009, 02:01 PM
Fobra
Banned
Fobra's Avatar
Well its probably you as a driver but, it could be a synchro, could be a lot of things, check her out a bit, check the obvious stuff and let us know
Fobra is offline
Old 05-27-2009, 04:13 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Say goodbye to your synchro... Theres a TSB out on grinding 3rd from Ford... Its a known problem for 3650s.
Time for a rebuild
WhiteFoxGT is offline
Old 05-28-2009, 06:14 AM
cisurfer
cisurfer's Avatar
how bad is the rebuild? keep in mind i did my own 373s...
cisurfer is offline
Old 05-28-2009, 07:41 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I've been a Ford tech for 3 years and I had some trouble when I attempted to rebuild my old T45... Basically had the master trans tech hovering over my shoulder telling me what to do. The 3650 is an even harder trans to rebuild. Its not something a novice should even attempt. Unless you have done a handfull of manual transmissions before I wouldnt even think of attempting it.
Old 05-28-2009, 08:17 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Here is the TSB, along with the replacement parts it also specifies using only 3.0L (3.2 qts) of fluid in the tranny--this reduces the tendency for the shift rods and detents to "hydrolock" when in motion.
I would also go back to using the RP Synchromax, or Mobil 1 ATF (which is Tremec's recommended fluid--see below). The Pennzoil Synchromesh fluid is spec'd only for GM and Chrysler per their web page...
From the TR3650 shop manual:
cliffyk is offline
JDWalton
09-24-2015 08:47 PM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
degner122
09-16-2015 07:09 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: 3rd gear grinds on fast shifting
