Trick flow stage 1 cams
Has anyone tried these? They're $450 through Summitt, and $600 with springs.
They also used the stage 1's with their new modular Trick flow heads, and acheived great numbers.
Wouldn't it have been better to use their stage 2's with the heads? Or are these just that good?
Actually Summitt has them for $450 with free shipping, and $600 with springs.
The guy i talked to at TF said they do work well with their heads (obviously) but said they are great on their own as well.
I'm no expert on cam specs, but they appear to be a fairly aggresive stage 1 cam.
They are 228/230 with .550"/.550" lift. I'm not sure what LSA they use. They are larger than my Stage 1 but smaller than my Stage 2. Im sure they wanted to see the results on a more typical "daily driver" set-up....hence the use of Stage 1's. They wanted to dyno test the heads with some of my grinds because of the tighter LSA..but I can't afford to send them cams for free.
