Hooking up a saleen electrical boost gauge and saleen air temperature gauge. white/red wire from gauges to gray/red wire on pcm PIN 91 and a gray wire from gauges to gray wire PIN 39 on pcm.
Here is a 1999 to 2001 Cobra 4.6 Pin Out. The numbers shown here on this PCM wire connector should be in the same sequence as your wire connector terminal. Not sure about the Fords, however the numbers for the Chevy PCM's are on the wire connectors itself. The protective rubber covering has to be removed to view the numbers for the Chevy wire connectors. I would think that the Fords are the same. Hope this helps. Good luck, Tommy.
